Indesit Washer wont fill, then drains model WIL113
Russell77
by Russell77 » Sun Feb 21, 2010 8:11 pm
My indesit wil113 starts to fill for about 2 seconds then stops and then only drains. Pump is working and water flow fine. Initially I discovered a fault after the fuse in the plug blew. On replacement it hasn't blown again but took the pressure sensor switch off and blew down the pipe freely. Blew into the pressure switch and clicks ok. Presuming the fault is with the pcb simply from the blown fuse.
Same problem on every cycle. Any other ideas fellas? If anybody can recommend a supplier of replacement parts id be very grateful or even better used parts.
Russ
It is currently Sat Nov 23, 2024 2:30 am
