1 switch to 6 lights?
zooty
by zooty » Thu Feb 25, 2010 3:00 pm
i would like to replace the single light fitting in my hall with 6 at intervals along the length of the ceiling.
i'm pretty certain i understand the wiring diagram but unsure if there's a limit to the number of lights running from one switch.
thanks for any info.
zooty
by sparx » Thu Feb 25, 2010 5:31 pm
no limit as the switch will be rated at the same as the supply fuse for the circuit, however there may be volt drop issues due to cable length,
regards,
zooty
by zooty » Fri Feb 26, 2010 11:50 am
many thanks for the prompt reply
z
It is currently Fri Jan 17, 2025 6:08 am
