Flueless GAS fires
davejohnparkes
Flueless GAS fires
by davejohnparkes » Fri Feb 26, 2010 9:37 am
I don't understand the concept of flueless gas fires. Does this mean I can buy a gas fire, fix it on the wall and there is no need to have an outlet for gas fumes?
DEEARR2
by DEEARR2 » Fri Feb 26, 2010 8:14 pm
No flue to remove fumes necessary, operates on the catylitic convertor principal. However, must be installaed as per manufacturers instruction taking into consideration calculated unrestricted direct ventilation and fire operating pressure. Recommend Registered installer to carry out install and commission.
davejohnparkes
by davejohnparkes » Sat Feb 27, 2010 8:32 am
Thank you for your reply, will take your advice re installation by qualified person.
by htg engineer » Sat Feb 27, 2010 7:26 pm
Go for an electric fire, they're just as effective for heating and look just as good.
htg
It is currently Fri Nov 22, 2024 12:08 pm
