Ceramic Hob - do I need to use a certain type of saucepan?
davejohnparkes
by davejohnparkes » Fri Feb 26, 2010 5:34 pm
Ceramic Hob - do I need a certain type of saucepan to use on a ceramic hob? I'm changing from gas to electric. Thanks.
by stoneyboy » Fri Feb 26, 2010 10:31 pm
davejohnparkes,
No you can any pan but do wrap a piece of fine emery round a flat block and rub this over the base of all your pans. This will remove any sharps which will scratch the ceramic surface.
davejohnparkes
by davejohnparkes » Sun Feb 28, 2010 11:10 pm
Great tip Stoneyboy.
It is currently Fri Nov 22, 2024 12:41 pm
