by Dan the man »
Sun Feb 28, 2010 10:05 pm
Depends on how you are using the term mitre???
A mitre is something thats cut at an angle, for instance you could use a mitre block to cut wood to join two pieces of wood together so they fit together perfectly, so for instance if someone said "you will need to mitre the coving so it fits together with the other piece then you would cut the piece of coving at a 45 degree angle and the other piece at 45 degree angle to fit together.
