Favorit 50750V1 with dead control panel
alpinenut
by alpinenut » Sun Feb 28, 2010 5:00 pm
I have a 7 year old Favorit 50750V1 that is no longer working. We have no power to the device, with no lights coming on any more on the door mounted control panel. Prior to this the device would not fill, with it making a gurgling noise. At the same time the machine issued a repeated 3 beep warning.
I've checked the filters inside the machine and they are all clean. The fuse in the main plug is also OK. There was also a leak at the water inlet where the inlet pipe connected to our water supply. The leak was not enough to cause a flood and looks like it has been there for some time.
I reckon the drain pump needs replacing, however, with the control panel no longer lighting up I'm wondering whether that is faulty too. If this panel needs replacing there is probably no point spending any more time on the machine due to the cost of parts.
Any help / advice would be appreciated.
Thanks.
It is currently Thu Jan 09, 2025 6:28 am
