Refilling Radiator system??
stEEvano
by stEEvano » Mon Mar 01, 2010 3:33 pm
Just put new radiators all round my house and about to fill up system but need to know what type of anti freeze sort of fluid i use (and how much to put in) and how to get it into the system??
acsimpson
by acsimpson » Tue Mar 02, 2010 3:31 pm
You don't generally need antifreeze in a central heating system. You do however need a corrosion inhibitor. The only one I have used came from screwfix but there are several on the market with varying qualities.
The bottle should tell you how much to use and you can put it into an empty system through any compression joint. Open the joint, pour it in and then close the joint again before filling the system.
stEEvano
by stEEvano » Tue Mar 02, 2010 8:24 pm
Thanks m8 :D
chris_on_tour2002
by chris_on_tour2002 » Tue Mar 02, 2010 9:06 pm
fernox central heating inhibitor is the choice of the professional. easiest way to add to the system is via the F&E tank (if you have one) or via a towel radiator (with valves closed BEFORE refilling system). alternatively you can get concentrated inhibitor in extruder tubes that you can apply via bleed valve on a radiator.
It is currently Sat Nov 23, 2024 3:26 am
