Limiting the damage
gholland
Limiting the damage
by gholland » Tue Jun 05, 2007 10:14 pm
Is there any reason why I shouldn't turn off the water supply to the entire house (at the main stopcock) before going away on holiday? This would surely limit the damage done if a plumbing problem occurs while I am away.
rdo1104
by rdo1104 » Wed Jun 06, 2007 3:51 pm
My parents always turned the water off at the main incomer when we went on holiday and this never caused a problem.
It would be worth ensuring your central heating is not set to come on as if you have a gravity fed or pumped system with a header tank as there would be no feed to replace any lost water.
It is currently Wed Nov 27, 2024 11:50 am
