power shower
ukbill
power shower
by ukbill » Wed Mar 03, 2010 1:13 pm
Can someone tell me what cable size should be required to run a power shower and does it need a pull switch same as a electric 1
kbrownie
by kbrownie » Thu Mar 04, 2010 3:26 pm
A power shower can be run off a 3amp fuse connection, so 1mm cable will do, an RCD unit will need fitting too, this comes under Part P of the building regs as notifiable work, if new circuit and or protective devices are being installed.
You can buy fused connection units with RCD protection incorperated.
a Power Shower is different to an electrical shower.
ukbill
by ukbill » Thu Mar 04, 2010 5:25 pm
[quote="kbrownie"]A power shower can be run off a 3amp fuse connection, so 1mm cable will do, an RCD unit will need fitting too, this comes under Part P of the building regs as notifiable work, if new circuit and or protective devices are being installed.
a Power Shower is different to an electrical shower.[/quote]
ok m8 thanks for your advice
It is currently Sun Nov 24, 2024 4:44 am
