water flow to bath
DEAN WHITTINGTON
water flow to bath
by DEAN WHITTINGTON » Mon Mar 08, 2010 9:35 am
I am fitting a new wall mounted bath mixer tap which was advertised as low and high pressure.
The system is low pressure but with a good flow, the new unit has restricted this flow to both hot and cold.
Can the tap be adjusted in any way.
Can I fit a shower pump to increase the pressure/flow.
Any other sugestions.
by stoneyboy » Wed Mar 10, 2010 8:39 pm
DEAN WHITTINGTON,
Buy and fit another tap which is low pressure.
Dave From Leeds
by Dave From Leeds » Thu Mar 11, 2010 12:39 pm
I'm not sure but I believe that some fixtures that are suitable for both high and low pressure systems have restrictors in them to cater for high pressure use. It may be that your mixer tap has these which, if removed, might eliminate your problem.
It is currently Thu Jan 09, 2025 6:47 pm
