Beading - Non flat edge
ldoodle
by ldoodle » Mon Mar 08, 2010 9:41 am
Hiya,
I need to nail some beading to the corners of an opening (used to be the external door until the extenstion was added) but the edges are not straight.
Basically there are a few small arcs down the edge which means the beading would be floating in those sections.
The top and bottom bits are OK so I can get a straight line from top to bottom but the bits in the middle are causing problems.
Is the only way round this to build up those sections with filler of some sort?
by stoneyboy » Wed Mar 10, 2010 8:43 pm
ldoodle,
"Is the only way round this to build up those sections with filler of some sort" YES fit the beading then fill the gaps.
It is currently Fri Nov 22, 2024 10:53 pm
