Knocking sound in cold water supply
rynso
by rynso » Wed Mar 10, 2010 12:43 am
Our cold water system has started knocking when taps etc are turned on and off. There is a noise like the pipe is being hit with a rubber hammer, but it is difficult to locate exactly where the noise comes from.
Any ideas of the cause and suggested solutions please?
rynso
by htg engineer » Wed Mar 10, 2010 7:36 pm
'There is a noise like the pipe is being hit with a rubber hammer'
It's called water hammer, caused by water coming to a sudden halt (closing a tap) causes the pipework to vibrate. This can be rectified by supporting pipework (clips) if any pipes are touching each other/floorboards/pipe boxing etc, clip and lag/insulate pieps
Firstly though, try closing the mains stop tap slightly.
Or if none of the above work, you could fit a water hammer arrester.
htg
rynso
by rynso » Thu Mar 11, 2010 9:48 pm
[quote="htg engineer"]'There is a noise like the pipe is being hit with a rubber hammer'
htg[/quote]
Many thanks.
rynso
It is currently Thu Jan 09, 2025 6:40 pm
