new toilet - push button cistern - flush no powerful enough
10 posts   •   Page 1 of 1
jdonnelly@thurrock.gov.uk
by jdonnelly@thurrock.gov.uk » Wed Mar 10, 2010 1:36 pm
new toilet - push button cistern - flush not powerful enough
any ideas on how to improve this ?
by htg engineer » Wed Mar 10, 2010 7:26 pm
Is the cistern full ? not just half full, you may have to adjust the water level.
If the cistern is full but the solids/tissue in the toilet doesn't flush, check the soil connection to the pan is falling away from the toilet and not rising.
htg
plumbbob
by plumbbob » Wed Mar 10, 2010 10:46 pm
It does not have one of those nasty flexible pan connectors with the ribs does it????
by jdonnelly@thurrock.gov.uk » Thu Mar 11, 2010 9:46 am
Thanks for your replies.
I will check out your advice, the water level is to the max line inside the cistern I am going to try filling above this line as much as I can. It just seems there isnt enough power behind the flush.
Will check waste fall.
I dont think it has ribbed connector but will check when I get home.
Thanks again
The soil is straight out doesnt seem to be fall either way.
Yes it doe have ribbed connector why?
Last edited by jdonnelly@thurrock.gov.uk on Fri Mar 12, 2010 1:35 pm, edited 3 times in total.
by jdonnelly@thurrock.gov.uk » Fri Mar 12, 2010 1:26 pm
yes it does have rib connector! Why?
by jdonnelly@thurrock.gov.uk » Fri Mar 12, 2010 1:28 pm
[quote="plumbbob"]It does not have one of those nasty flexible pan connectors with the ribs does it????[/quote]
yes it does why?
by jdonnelly@thurrock.gov.uk » Fri Mar 12, 2010 1:31 pm
yes it does have ribbed connector why?
mrlennie
by mrlennie » Fri Mar 12, 2010 7:27 pm
They seem to reduce flush...imagine your toilet waste is half blocked. Maybe not half blocked but not fully open as it was designed.
Although saying that I have installed 3 new toilets with push buttons and the cheaper the toilet the worse the flush seems to be no matter how high the water level is. I dont know what my advice would be as there could be many contributing factors. The cistern holds too little water, the path the water runs down the pan is slowed by design, the siphon could be opening half what it should be. A bit of all of these... I'm not there so I can't see...
by htg engineer » Fri Mar 12, 2010 9:05 pm
Raise toilet pan, so that there's a slight fall. If it's perfectly level then that'll be the problem.
htg
plumbbob
by plumbbob » Sat Mar 13, 2010 2:02 pm
I have come across this problem before when using the ribbed type connector. If the fall is very good to vertical, then they seem to work ok. If the flow is anywhere near horizontal for any distance, the ribs hinder the rate of flow to a degree where matter can be left unflushed.
It is currently Sat Nov 23, 2024 4:02 am
