Insulation fixing clips
ptfe15
by ptfe15 » Wed Mar 10, 2010 7:47 pm
I've seen some Insulation fixing clips somewhere on the net, but now can't find them...
Basicslly they are like a squared off Z section, with teeth to push into the celotex type insulation, and then a hole so that you can put a screw into the batten. [b]Does anyone know where I can get some?[/b]
They would be used to fix insulation (30mm celotex) between the battens so that the insulation does not fall out of the back.
I've tried Jewsons, Travis Perkins and Screwfix.... Thanks
It is currently Sun Dec 22, 2024 7:53 pm
