4 hole bath mixer - shower head siphoning any fixes?
kaner.dr
by kaner.dr » Sat Mar 13, 2010 10:19 am
I have a 4 hole bath mixer (hot, cold (quarter turn), bath filler, pull out shower head). All are set on a flat plinth next to bath. Frequently when turning on the tap (only) the shower head starts to leak water - perhaps due to a siphoning effect. Any suggestions on how to fix? Is it a problem with the design or a faulty part?
Thanks in advance
David
by stoneyboy » Sun Mar 14, 2010 5:33 pm
kaner.dr,
You do not name the make but I would suspect the lever/valve which directs the water to the bath or shower is not fully turned or its faulty.
It is currently Sat Dec 28, 2024 10:12 pm
