Dry concrete mix for building a low retaining wall
andrew77
by andrew77 » Wed Mar 17, 2010 5:38 pm
I am planning on building a low retaining wall using upright railway sleepers. I was going to use a dry mix like fence posts as the maximum height of the wall will be about 50cm and I was going to have the posts roughly 50% exposed above ground.
I was wondering if anyone had any thoughts about the concrete mix make up. e.g, amount of cement to aggregrate / sand
Many thanks
by stoneyboy » Sun Mar 21, 2010 8:58 pm
andrew77,
Use postfix or something similar - its quick and easy.
It is currently Wed Jan 08, 2025 3:13 am
