Replastering 1 meter up wall after Damp Course
chips
by chips » Tue Mar 23, 2010 12:22 pm
I've removed render and skim coat aprox 1 meter up the wall where damp is coming through wall. External bridge of damp course removed, additional Damp Course injection done, inside re-rendered with sand and cement. What's left is the skim coat.
My question is whether i must skim right up the wall or if i can blend the skim coat into the wall above the newly rendered area. Cheers
by stoneyboy » Tue Mar 23, 2010 10:52 pm
chips,
"can blend the skim coat into the wall above the newly rendered area" YES
Dan the man
by Dan the man » Wed Mar 24, 2010 1:54 pm
Depends on how good you are at skimming lol
If the wall is going to be painted afterwards then chances are you will see a slight join. If its your own house then I would skim the whole wall.
It is currently Wed Nov 27, 2024 10:39 pm
