culvert drains
Ask questions and find answers on a range of subjects relating to self build projects
m forrest
culvert drains
by m forrest » Thu Jun 07, 2007 2:17 am
i need instructions for installing a culvert drain frame and how to close in the top grating please!!
thedoctor
by thedoctor » Fri Jun 08, 2007 8:46 am
Need more information than that. There are hundreds of types of drain and the ready made ones, which are cheap as chips, come with grids which just clip into place on the top. Please see our project on brick and block paving and you will see a drive drain at the bottom. This is used essentially for drainage accross a driveway usually if the driveway is sloping towards the property of garage. The water can then be directed to a surface water manhole or soakaway. See also our project on French Drains and Soakaways.
It is currently Sun Jan 05, 2025 4:57 am
