Loud noise from pipes after flushing toilet
rubytuesday
by rubytuesday » Thu Jun 07, 2007 11:30 am
Can you help? When the toilet in my small cloakroom is used a loud noise which lasts approx 30" comes from the pipes - when tap is switched on, the noise disappears but returns as soon as tap is switched off.
thedoctor
by thedoctor » Thu Jun 07, 2007 12:14 pm
Go to the projects section as advised. The project is called noisy pipes
by htg engineer » Thu Jun 07, 2007 2:39 pm
sounds like the ball valve is vibrating, try reducing the flow of water to the toilet, alternatively re-washer or renew ball valve.
It is currently Mon Dec 23, 2024 8:52 am
