Outside Circuit / pond pump
derekhogg
by derekhogg » Thu Jun 07, 2007 12:44 pm
Hi.
I have a socket in an outside shed, I have recently put a pond in the garden. I would like to run armoured cable from the socket using an RCB, around the garden fixing it to fence posts to a purpose built weather proof switched connection box, then connect the pond pump using using the 3m weather proof cable supplied.
Can I do this?
Derek
sang kibet
by sang kibet » Mon Jun 11, 2007 11:13 am
Dererhogg, running armoured cable is not a bad idea.except that you should conform yourself to regulations concerning special installations on damp areas.you can also use mims cable.ensure that your installation is well earthed and use of the right cable entries into any box.Important! make sure the right size of the cable is used.this ensures that their is proper division of currents and reduce voltage drops..>sankibe>
by sparx » Mon Jun 11, 2007 5:05 pm
Hi D.H. further to other comment, this is covered by bldg regs part p so you cannot legally DIY ANY outdoor wiring,
regards SPARX
It is currently Sat Nov 23, 2024 7:51 am
