EARTHING A LIGHT
gamblinharry
EARTHING A LIGHT
by gamblinharry » Tue Apr 13, 2010 12:35 pm
Hi all,
I've just bought a new outside light to replace the existing one. However, when I've come to fit it, I've noticed that there is no earth wire attached to the existing light. The light is operated by a single gang switch and there is no earth attached to that either.
Can I spur off an earth from another nearby light fitting and attach this to both the light and the switch.
Any advice welcomed.
Many thanks.
by ericmark » Wed Apr 14, 2010 2:52 pm
Google "esc.org.uk/business-and-community/electrical-industry/best-practice-guides.html" and down load ESC Best Practice Guide No.1 Issue 2 which details this problem.
Basic you need to use lights which are double insulated until you re-wire.
The earth wire has to follow the same route as live wires and if not included with live wires be at least 4mm which means it is as easy to renew wires as add an earth.
Taking earths from else where is not really any good as the supply to that item could be isolated in the future which would mean losing earth again.
The rules on earths are getting on for 40 years old which means at 10 yearly tests you should have had it re-done by now.
It is currently Thu Jan 16, 2025 10:06 pm
