Problem with existing foundation
rtlite
by rtlite » Thu Jun 07, 2007 9:49 pm
We have a home built on a slab(30 years old) on block foundation. Each winter the slab moves down away from the ceiling, breaking the dry-wall tapped joints at different points. Once the frost is gone it returns to a normal state. Is there a reasonable solution to this problem, short of starting over? I have been considering a "French drain" thinking water is at the root of my problem.
thedoctor
by thedoctor » Fri Jun 08, 2007 9:50 am
French drain or drain channels would be the starting point and see what happens. Impossible to guess answers on a forum and any suggestions involving structural work could be very dangerous so if you get any, please check them out with a buiulding surveyor on site.
It is currently Mon Jan 20, 2025 12:10 pm
