Make door wider with stick on strip.
mandarin
by mandarin » Fri Apr 23, 2010 10:02 am
Needing to replace front external door.
Joiner says cannot find door to fit or to cut down but can finf a door that will require a half inch thick strip stuck on the edge to make it fit gap.
This would be on the hinge side.
He assures me this will be fine but I have my doubts as to how the future life of the door will be affected - strength etc.
Any views welcomed.
by stoneyboy » Fri Apr 23, 2010 9:06 pm
mandarin,
Sticking a strip on the door will always be a problem area especially if the door is exposed. See if you can find a reclaim yard with a reasonable 2nd hand door or get a bespoke one made.
It is currently Fri Jan 10, 2025 4:36 pm
