Replacing an electric double oven with a single oven
craigr12
by craigr12 » Tue Apr 27, 2010 8:27 pm
Hello,
Our double oven is on its last legs and we're looking to replace it with a single. Is it simple a case of slipping the old one out and slipping the new one in?
Thanks,
Craig
collectors
by collectors » Wed Apr 28, 2010 8:41 am
Width should be the same, but will need an infill either top or bottom for the gap that will be left.
On the electric side! If it was a double oven, there is a 99% chance that its on its own supply from the main fuse board with a 30/45amp cooker switch in the kitchen as an isolator. If this is so? it will need the isolating switch changed to a switched fused spur , fitted with a 13amp fuse. This can only be done if the isolating switch is of the singe plate size.
Another alternative would be to just change the fuse at the fuse board from a 30/45amp down to a 16amp mcb.
All of the above should be carried out by a registered part P electrical installer & would not be just a straight swap.
It is currently Tue Nov 26, 2024 6:37 pm
