High level cistern siphon
Poppy 48
by Poppy 48 » Sun May 02, 2010 4:41 pm
Can you help me? We've installed a new siphon into a high level Sanitan cistern but the lever rises too high and hits under the lid. Can anyone tell me how to reduce the travel on the lever? Thanks.
plumbbob
by plumbbob » Sun May 02, 2010 11:39 pm
The wire link that joins the syphon and the handle is available in two lengths. My guess is you are using the longer version which is allowing the lever to lift too high.
Poppy 48
by Poppy 48 » Mon May 03, 2010 11:30 am
Thanks Plumbbob, we've tried both sizes of the wire link and even with the shorter one it still comes up higher than the lid, albeit by less. I'll maybe talk to the manufacturer to see if they have encountered this problem before and if so, how they solved it. But thanks so much for your help, I'm really grateful for your time.
plumbbob
by plumbbob » Wed May 05, 2010 12:20 am
I have seen this problem before, but have always been able to overcome it by fiddling with the link and lever. If you shorten the link by bending it and by possibly hooking it into a different hole in the handle arm, you can get it to flush without the lever being turned to a degree where it contacts the lid.
Any extra length in the lever can also be cut off which will reduce the possibility of it hitting the lid.
It is currently Fri Jan 24, 2025 11:06 pm
