small retaining wall with railway sleepers
dom71
by dom71 » Mon May 03, 2010 10:00 am
Hiya. I'm new to these boards, so forgive me if I do anything wrong.
I need to build a low retaining wall for the garden (since I had some building work done.) I plan to use railway sleepers (new ones, not reclaimed.) The dimentions of the sleepers are 24cm x 12cm x 2.4m. Total height needed above ground level is about 30cm.
As you can see from the photo, I plan on putting them in 2 high, using the height rather than the width. The bottom sleeper will be well over half underground (as per piccie). I plan to link the sleepers together with Timberlok fasteners
My questions are ....
Do I need footings for this - concrete etc or am I OK just tampening the ground ? If I need concrete, what depth would you use?
Do I need vertical posts to secure the sleepers with - or should I be OK without (I thought I would be OK without because it isn't very high).
Any advice would be most welcome. Please bear in mind I'm far from experienced though.[/img]
by stoneyboy » Thu May 06, 2010 10:21 pm
dom71,
Should be OK for stability with bottom sleeper partly buried. How quickly the bottom sleeper will rot is another matter.
dom71
by dom71 » Sat May 08, 2010 10:55 am
OK thanks. I thought the idea of these sleepers was that they were pretty rot resistant? Should I be treating the bottom layer beforehand then? How long are we talking about? Years, decades?
by stoneyboy » Sat May 08, 2010 7:33 pm
dom71,
"How long are we talking about?" depends on the timber quality, ground conditions and how well the timber was pressure treated. If you are unlucky it could be 5 years.
It is currently Wed Jan 08, 2025 3:23 am
