SEALANT PAINT HELP!!!!
ClanMoffat
by ClanMoffat » Mon May 03, 2010 2:18 pm
Hi!
We have made the mistake of using Bathroom & Shower Sealant to cover screwas and gaps on SKirting Board fittings and then noticing that the sealant does not take paint.....
Apart from removing the sealant and skirting boards and starting again the only other idea I have would be to remove as much of the sealant as possible and then try to cover it with paintable sealant such as polyfilla...
ANY other suggestions wvery welcome.......
gc1967
Re: SEALANT PAINT HELP!!!!
by gc1967 » Thu Feb 21, 2019 9:43 pm
Remove as much sealant as you can and apply stain block to the areas and then fill up and then undercoat and gloss your woodwork again
It is currently Fri Nov 15, 2024 8:30 am
