steel window frames
rod austin
steel window frames
by rod austin » Tue May 04, 2010 8:19 pm
how do i remove steel sub frame from existing good timber window frames without damaging timber frame?
by stoneyboy » Thu May 06, 2010 10:41 pm
rod austin,
There will be screws fixing the steel frame into the timber - you may have to dig out the putty to expose the screw heads. If you are lucky you will be able to remove all screws and then lever out the steel frame.
It is currently Mon Dec 23, 2024 5:30 am
