Extending opening at back of house
eod
by eod » Fri May 07, 2010 8:36 am
There are currently some fairly old, smallish french doors at the back of my house and I am thinking of extending the opening & fitting new, wider more standard size doors.
This would involve altering the brickwork. I want to find out what this would involve before deciding who to hire / what i can do myself.
There are 'soldiers' (bricks postioned vertically) over the doors at the moment (as there are over our windows). I presume these act as a sort of lintel?
Would it be possible to hold the brickwork above the door with acros, insert a bigger lintel & then chop out the brickwork as necessary or is this oversimplifying things.
Many thanks,,,,
by stoneyboy » Sat May 08, 2010 7:38 pm
eod,
"I presume these act as a sort of lintel?" No they don't.
You will need to fit a new lintol to support the wall which may be a cavity wall. Your description is simplifying things but broadly correct.
eod
by eod » Sat May 22, 2010 11:04 am
many thanks Stoneyboy,
out of interest, if the soldiers (vertical bricks) aren't for support are they purely decorative?
by stoneyboy » Mon May 24, 2010 9:40 pm
eod,
"are they purely decorative" YES unless they are in an arch form then they would be for support.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Fri Jun 25, 2010 6:43 pm
Let DIY Doctor help you to find quotes from vetted and trusted tradesman local to your area. Visit our Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Tue Nov 26, 2024 9:49 pm
