FITTING A ELECTRIC SHOWER
sullymann
by sullymann » Sun May 09, 2010 2:07 pm
MY COMBI BIOLER BROKE DOWN CARNT AFFORD ANOTHER CAN I INSTALL A ELECTRIC SHOWER TO GET HOT WATER IF NOT BEST WAY TO SORT HOT WATER CHEAP NOT BOTHERED ABOUT HEATING JUST NEED A BATH
by htg engineer » Mon May 10, 2010 4:54 pm
Is the boiler beyond repair ?
Fitting an electric shower is cheaper than a new boiler boiler, but still not that cheap.
You're looking at £70+ for the shower, Then you need a plumber ? and you definitely need an electrician as you have to have part P, you need a new circuit back to mains board so not a quick/easy job. All in all probably looking at between £180 - £220.
htg
It is currently Fri Jan 10, 2025 4:01 am
