fitting new ceiling in garage
guitsax
by guitsax » Mon May 10, 2010 10:17 am
Hi I'm converting a garage into living space -- and need to fit a ceiling. What is the thinest battens that can be used to support ceiling board 9,5mm.
brithebuilder
by brithebuilder » Wed Jun 02, 2010 12:04 pm
Hi, your better off using galvanised ceiling channel from Knauf or similar screwed to the joists , with the board fixed with 25mm drywall screws. This will reduce the chance of cracking due to timber shrinkage. You really should be using 12.5mm board with the channels at 450mm centres.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 9:39 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Fri Nov 22, 2024 6:55 pm
