Loft conversion purlin replaced by knee wall
jaamiller
by jaamiller » Fri May 21, 2010 2:48 pm
I have purchased a house which had plans and engineering diagrams for a loft extension in its cut and pitched roof. The back of the house is to have a full-width dormer, the front staying as a sloping roof.
The plans seem to suggest that the purlin on the sloping roof is removed, and the rafters supported on a knee wall which rests on an RSJ embedded in the load-bearing end walls.
The knee wall will bear the weight of the roof vertically downwards onto the RSJ, and the rafter spans conform to the relevant building regs tables.
What is worrying me is that the purlin is currently supported by wooden struts that are at 45 degrees, giving support to the rafters vertically and horizontally. The knee wall will have little or no support in the horizontal plane. The engineers plans are sketchy to say the least, and the plans give no hint that horizontal support is required,
Does it need any?
by stoneyboy » Mon May 24, 2010 9:48 pm
jaamiller,
Start by getting the plans checked by an architectural technician, he will then refer any dubious bits to a structural engineer.
brithebuilder
by brithebuilder » Sat Jun 05, 2010 9:25 pm
Hi, the main reasons that struts are added to purlins are to either shorten the effective length or to prevent them bowing down the length of the rafters. The main reason the purlin bows is if it's at an angle rather than vertical. When your new wall is built it will have a wall plate on top and ideally this should be birdsmouthed into the rafters, that way the imposed load will be vertical.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:04 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Fri Nov 22, 2024 6:26 pm
