Conservatory Electrics
Conservatories are a great all-round addition to any home. Find help, advice and information on all aspects of this area.
andy21275
by andy21275 » Sat May 29, 2010 3:01 pm
Hi all,
Just erected my new conservatory and now down to running the electrics. I have bought 3 double sockets, light switch, wire, channelling etc and a 13amp rcd protected fused connection unit. I was planning on spuring off my kitchen ring main into the fused rcd unit, then running the 3 sockets off the rcd unit in a radial circuit around my conservatory.
Now reading the back of the box for the fused rcd unit it states you can only run 1x 2gang socket from the unit, why is this?
I have read i cannot extend my kitchen ring main without b regs notice.
Sockets will only be powering pc, lcd tv and maybe my sons xbox.
Has any one got any ideas the best way forward.
Any help would be most appreciated
cheers
andy
by stoneyboy » Sun May 30, 2010 8:39 pm
andy21275,
Once you have fitted a fused spur you can add as many sockets as you like into the circuit fed by this spur.
You will need BR approval or a "competant person" to certify the works with a minor works certificate.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 8:26 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Fri Nov 15, 2024 4:51 pm
