Help pls wiring a simple external light..
quadcore64
by quadcore64 » Sun May 30, 2010 2:16 pm
Hiya everyone lovely forum indeed! im new so id firstly like to say hi to the FE & hi to you guys!
IF anyone needs any pc help ive used them since 1984 so i do have a decent amount of use sometimes! lol
Anyway im in a dilema ive got a external light switch (Il provide photos below) & its a basic one way light one end is fitted with a plug & the other to the light but the switch is throwing me! i am lost as to where the routing goes can anyone help me pls!
thankx
Now the links..
http://i178.photobucket.com/albums/w275 ... 72/058.jpg
http://i178.photobucket.com/albums/w275 ... 72/056.jpg
http://i178.photobucket.com/albums/w275 ... 72/055.jpg
by ericmark » Mon May 31, 2010 12:34 am
Any answer is a guess and of course could be wrong. However the switch seems to be change over switch rather than double pole on/off so either you will not switch neutral and both neutral and earths will use a block connector or you need to change to double pole switch.
Since outside light likely it will come under Part P see Projects:https://www.diydoctor.org.uk/projects.htm for more info and links.
It is currently Tue Nov 19, 2024 7:52 pm
