How access kitchen tap's cartridge / washer??
jjsandall
by jjsandall » Mon May 31, 2010 8:30 pm
My kitchen tap, which was installed by the previous owner, has been dripping for a couple of weeks. I know I need to see if the washer / cartridge inside needs replacing, but cannot work out how to access it. THe tap 'handles' have no grub screw or cap hiding a fixing. I've tried pulling hard, and forcing with a screwdriver but am reluctant to apply too much force in case I break it. The kitchen was manufactured by Magnet, and I presume the tap is one of theirs too, but cannot find any info on the internet to help.
I can remove the spout, but not access the main body of the tap.
Can anyone offer me some guidance? I was hoping this would be a simple job, as other tap repairs in my home have been, but it's proving rather annoying! Thanks very much.
PS: Hopefully a pic of the tap is attached. As stated, no obvious grub screw or hidden cap / plate hiding a fixing.
plumbbob
by plumbbob » Mon May 31, 2010 11:16 pm
With some of these style taps the lever bar on the handle can be removed by unscrewing. This will reveal a small grub screw which can be removed with an allen key. Once removed the "handle" can be removed.
jjsandall
by jjsandall » Tue Jun 01, 2010 10:35 pm
Spot on Plumbbob - thanks for your advice! All sorted now.
willowcourt
Re: How access kitchen tap's cartridge / washer??
by willowcourt » Tue Sep 27, 2011 11:41 am
Hi, I have the same tap, where did you get the cartridge from and how much.
Do you also have the make or model and cartrigde information.
Much Apprecaite it.
It is currently Fri Jan 10, 2025 8:10 pm
