Bubbles in newly painted wall.
6 posts   •   Page 1 of 1
Andy Cross
by Andy Cross » Thu Jun 03, 2010 10:50 pm
I have just repaired a crack in a wall by filling and then sanding flat. I had to sand down to the plaster to remove the step then put a layer of white emulsion on before the end colour. While the paint was drying I noticed several bubbles appeared around the area of the crack. Anyone have any ideas why this happens?
by stoneyboy » Sat Jun 05, 2010 12:49 pm
Andy Cross,
Did you thin down the first coat of emulsion? If not this is the most likely cause of bubbling.
JRS
by JRS » Sat Jun 05, 2010 8:44 pm
Never heard of thin emulsion blistering. What filler did you use. Was it over wallpaper, lining paper. Filler must be completely dry before sanding and painting and dust free.
Andy Cross
by Andy Cross » Sat Jun 05, 2010 9:15 pm
No I didn't thin the first coat I didn't know I had to. How thin would you make it?
by stoneyboy » Sun Jun 06, 2010 9:10 pm
Andy Cross,
Something like 3or4:1 depending on the thickness of the emulsion - it needs to be really watery.
JRS
by JRS » Wed Jun 09, 2010 1:46 pm
Andy Cross wrote:No I didn't thin the first coat I didn't know I had to. How thin would you make it?
This may be why it blistered. 70% water or just get bnq stuff 5r for 5l and its more or less water. Thick/full emulsion will just sit on the surface of new plaster.
It is currently Fri Jan 10, 2025 10:57 pm
