patio pointing cracking
donnybaggieboy
by donnybaggieboy » Sat Jun 05, 2010 3:02 pm
i have just pointed between my garden slabs and it has already cracked and loose after a week iused a mix of 3to 1 building sand and cement and put it in as a wet mix.it is very frustrating as most of it is still ok .should i re-do it using sharp sand instead of building sand.the patio is used for foot traffic only
by stoneyboy » Sun Jun 06, 2010 9:13 pm
donnybaggieboy,
Wet the cracked areas and work in the same mix.
jacktaylor709
by jacktaylor709 » Fri Apr 01, 2011 7:29 am
You should heal this problem by using mixture of sharp sand and cement.By mixing it the cracks are covered up and removed from the floor.......
Hope this information helps you........
It is currently Sun Dec 22, 2024 8:18 am
