which shower???
6 posts   •   Page 1 of 1
stupot
which shower???
by stupot » Sun Jun 06, 2010 9:52 am
Hi,my daughter has moved to a ground floor apartment,there is a shower/bath mixer tap which has a quarter turn handle on hot and cold,the cold feed is very high and this totally kills the hot feed,i have tried turning cold water pressure down but to no avail,i am considering putting her an electric shower in or maybe a thermostatic mixer but am unsure which is the best road to go down,any help would be much appreciated thanks.
by htg engineer » Sun Jun 06, 2010 2:30 pm
A thermostatic mixer will be no good as you'll have the same problem as you're having now, obviously not a combi/mains pressure hot water.
htg
plumbbob
by plumbbob » Sun Jun 06, 2010 3:00 pm
htg engineer wrote:A thermostatic mixer will be no good as you'll have the same problem as you're having now, obviously not a combi/mains pressure hot water.
htg
Unless you take the cold feed for the shower from the header tank so both feeds are at the same pressure
stupot
by stupot » Sun Jun 06, 2010 3:14 pm
no its an all electric apartment so its got a tank,what about a prv?
by htg engineer » Sun Jun 06, 2010 8:43 pm
As you said in your first post it's a ground floor apartment - if you do as plumbbob says the cold pressure will be very poor - like the hot is now, you could pump it.
But as you say the cold water is good so why not use it - go for an electric shower.
htg
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Tue Jul 06, 2010 9:37 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Fri Jan 10, 2025 10:03 am
