Kitchen Flat roof to pitch + Insulation
Lexifir
by Lexifir » Wed Jun 09, 2010 9:01 am
Hi guys. This is my first post here.
I've been poking around websites about insulating a pitched roof, but I always end up with loft conversions, or insulating a loft.
I had a flat roof on the kitchen, which is an extension to the original house. The flat roof leaked, and we decided to upgragde to a sloping roof. (Slopes from one high side, down to the window, rather than having a point and sloping both ways) The property is terraced, thus sloping one way only, the neighbours have a part pitch, part flat roof.
Can you guys tell me;
1. The insulation that I need to put in.... Can it go directly under membrane that was installed as part of the build, or does it have to have a vapor barrier plastic sheet installed first?
Currently have tiles on the roof, next layer down is this waxed fabric sheet (don't know correct name for it),
2. Is there a minimum R value that must be installed in a roof like this?
I currently have Foil backed Rockwool type insulation that has a depth of 150mm and an R value of 3.81. £50 a roll :cry: but I wanted decent stuff, I'm hoping I don't need more than that. (Roof inside will then be plasterboarded, skimmes and painted)
3. Does a vapor barrier add anything to the R value insulation of the roof? (I'm guessing not, but it's worth checking...)
Cheers guys, hope you can help me. :lol:
It is currently Sun Dec 22, 2024 11:40 pm
