water pump
ukbill
water pump
by ukbill » Mon Jun 21, 2010 5:06 pm
hi i have a stuart and turner, monsoon, negetive head ,twin impeller pump
which runs the water ok but when not running is making a load noise,it sounds like it is trying to start,there is a cylinder on the pump which has a filling loop to it and on the top is a valve that looks like a inner tube valve for air i pressed the valve and nothing came out from it,is this supposed to be gassed up or just filled with air,i was thinking maybe that is the problem with it,althought the pumpis quiet a few years old now.any idea anyone please
plumbbob
by plumbbob » Wed Jun 23, 2010 6:16 pm
Google
stuart-turner.co.uk/products/monsoon/u20-bar-twin
and look at the the the bottom of page 16 of the Installation Manual. It tells you how to re-pressurise the vessel.
If the PV is empty, the pump will hunt (switch on and off repeatedly).
It is currently Sun Nov 24, 2024 4:35 am
