Bosch Ovens - Not making Roasts crisp!!!
Newmum31
by Newmum31 » Tue Jun 29, 2010 8:14 pm
Hi Please can someone help me. As a new mother I am trying to be the perfect wife!!! My Double oven is working however the main oven has stopped making things crisps like roasts, jackets etc. It worked before however all of a sudden it has started playing up, not sure if it is because I have been cooking a lot of stews and there is a moisture build up? Can anyone give me any advise.
by ericmark » Wed Jun 30, 2010 11:48 am
I could be that the thermostat is damaged. When just married we had what was then (1970's) a new fangle fan oven which seemed to burn everything and we blamed it on the fan and compensated by giving either less time or lower temperature.
It was not until years latter with second Belling fan oven that we realised it must have had a faulty thermostat.
If you can get hold of an oven thermometer you should be able to check this and if faulty either manually compensate or get the thermostat replaced.
It is currently Thu Jan 16, 2025 5:45 pm
