plumbing hot water
andyw4516
plumbing hot water
by andyw4516 » Wed Jun 30, 2010 7:02 am
have no hot water comimg from taps hot water in tank, have tried back flushing with cold water pressure no success. was working ok but turned off to change bath now no hot water.there is no cold water header tank, just hot water cylinder and when you turned off cold water mains supply it also stopped hot coming out, have done this before and when turned back hot water came straight back on ???? any suggestions[list=][/list]
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Tue Jul 06, 2010 9:21 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
lilieyen10
by lilieyen10 » Mon Jul 19, 2010 4:38 am
I just want to say that you should be careful in plumbing your hot water because plumbing is not an easy work. If you are plumbing with copper, be sure to sweat fittings onto pipe before attaching it to the heater.
jamespipers
by jamespipers » Wed Sep 01, 2010 5:08 pm
You should find an expert plumber to make the pipe fitting for you. The water heater should need some repair too.
online
It is currently Fri Jan 10, 2025 9:12 am
