Compression Joints
martin g
Compression Joints
by martin g » Mon Jul 05, 2010 6:12 pm
Hi everyone,
i want to re-use a turn off point which has compression fits on each end.
Is it okay to reuse if i used new olives?
Cheers Martin
by htg engineer » Tue Jul 06, 2010 7:01 pm
Yes, just replace olives/rings. On some older fittings you will need the original nuts too, as the threads are sometimes different.
htg
It is currently Wed Nov 27, 2024 7:34 am
