repairing light hole in wooden ceiling
ma
by ma » Tue Jul 06, 2010 3:51 pm
the first owners have put a toung and groove wooden ceiling straight on the floor joists, is this acceptable? secondly they have large recessed lights in the ceiling which i want to remove, but i will be left with a large hole. Since i want to re arrange the room layout and put a studding wall in this room i need to move the position for new lights. Any easy way of fillling this hole? please help, :(
by stoneyboy » Tue Jul 06, 2010 11:07 pm
ma,
Current BRs require 12mm platerboard and skim so no T&G does not comply. Cut away a square section of the T&G where the light was fitted and fit T&G to fill the square hole.
Do not fit dichroic lights in this wood ceiling they get very hot and will create a fire risk.
ma
my wooden ceiling
by ma » Thu Jul 08, 2010 12:18 pm
would it be acceptable to screw plasterboard striaght on the t and g ceiling?
by stoneyboy » Thu Jul 08, 2010 11:38 pm
ma,
Overboarding with plasterboard is the cleanest and easiest solution, you will get cracks around the edges of the room but some coving will cover this problem area.
It is currently Fri Nov 15, 2024 12:36 pm
