hot/cold water pressure booster
artashh
by artashh » Thu Jul 08, 2010 6:52 pm
Hi Guys hope y ou can give me some advice.
In my flat i have a cold water tank and an indirect hot water tank, however, when having a shower i have no water pressure, the water tanks are installed lower than the actual shower head (when put high) level, so in order for me to have a shower is to sit down in the bath and hold the shower tap in one hand and wash with the other hand.
I would like to get someone to install a pump but i dont know what kind of pump i need, i dont need anything heavy duty as such, just a plane pump to boost water into my bathroom so i can have a normal shower like a normal person. Can anyone advise me what kind of pump i need for my flat.
Thank you guys in advance
TheDoctor4
Help!
by TheDoctor4 » Fri Jul 09, 2010 8:51 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
aia21
Re: hot/cold water pressure booster
by aia21 » Fri Aug 06, 2010 9:42 pm
artashh wrote:In my flat i have a cold water tank and an indirect hot water tank, however, when having a shower i have no water pressure, the water tanks are installed lower than the actual shower head (when put high) level, so in order for me to have a shower is to sit down in the bath and hold the shower tap in one hand and wash with the other hand.
Just install a power shower. That contains the correct pump and is suitable for your system and will give you a nice strong shower. You will need a plumber to fit the plumbing for it and a Part P qualified electrician to do the electric supply to comply with building regs (or you could do yourself and get a Part P qualified electrician to sign it off but you might want to check with your building regs department they are happy with that first).
Hope this helps.
Best regards,
Anton
It is currently Sat Jan 25, 2025 8:59 am
