pull switch
fredobryen
pull switch
by fredobryen » Sat Jul 10, 2010 11:04 am
hello, i am trying to put a new pull switch in my toilet as son pulled old one off ceiling!!
i have four cables!!
one is supply ; red black earth
one goes to light; red black earth
one goes to fan; red black earth and yellow?
fourth cable goes to power other lights.
i have new switch but no ideas on how to wire them!
help
by ericmark » Sun Jul 11, 2010 9:31 pm
All earths connect together so I will not say any more about them.
Black will likely need a terminal block we will call it neutral. Red to Common if there is no common then it may be called L for line.
Black with other black neutral and red to L1 on switch i.e. remaining terminal.
This is a problem as no standard wiring likely red to Common, Yellow to L1 and Black to neutral.
Red to Common, Black to neutral block and earth with all other earths.
fredobryen
THANKS
by fredobryen » Fri Jul 16, 2010 1:38 pm
ericmark wrote:All earths connect together so I will not say any more about them.
BIG THANKS TO ERICMARK - ALL SORTED!!!!
It is currently Thu Jan 16, 2025 4:13 pm
