Which faceplate for double gang socket?
Masterpop
by Masterpop » Sun Jul 18, 2010 10:20 pm
Would anyone have any strong opinions on which wall socket faceplates are good quality and should be installed?
Personally, I'm a fan of MK equipment, for historical reasons, although the most recent ones seem not be "made like they used".
Also, does anyone know any faceplates which can take 2 4mm wires?
by ericmark » Mon Jul 19, 2010 9:28 am
All sockets should take two 4mm wires but MK claim two 6mm wires. As to quality only when max is drawn does one really test the socket and the normally failure is due to over heating. If course metal conducts heat better than plastic so metal faced sockets tend to last better and don't show discolouring even if it happens. However impact damage can be hidden.
I like MK as the holes are slightly bigger so easy to work with and the grid range do seem better made than others but really it is impossible to tell. As an electrician we very rarely get to know why a socket failed. People are loathed to admit the pulled on the vacuum cleaner cord or plugged in a 20A electric welder only the users really know what they have done.
It is currently Tue Nov 26, 2024 11:42 am
