wood burning stove
urquhart1690
wood burning stove
by urquhart1690 » Wed Jul 21, 2010 10:49 pm
i have recently purchased a very small wood burning stove for a stone built outhouse, the flue i require is 3m long but can not afford the real deal as they are so expensive. Would i be able to use a length of 4" cast iron down pipe instead? If so how can i insulate the pipe as it passes through the flat roof?
wulls
by wulls » Sat Sep 11, 2010 5:30 am
The flue of a wood burner needs insulated for a reason......it gets very very hot and if you continue this madness you will eventually touch it and get 2nd degree burns if you are lucky.
I suppose the place may burn down before you hurt yourself but either way I can see much sadness.
The building regs man would have kittens if he seen what you propose.
Please please go out and buy a proper flue.......
crismartin875
Re: wood burning stove
by crismartin875 » Sat Jan 23, 2016 8:14 am
No you can't use iron pipe becoz its get hot when hot air passes through it and a cemented and insulated pipe not create this problem.
It is currently Thu Oct 31, 2024 6:17 pm
