Stubborn wall - help!
tonyade
by tonyade » Thu Jul 22, 2010 4:49 pm
Hello chaps.
Just trying to drill a hole above my front door. Using a standard drill with masonry drill bit. Can only seem to make a hole measuring a couple of inches. Pretty sure there's no metal where I'm drilling.
Can't figure out what I'm doing wrong. Wrong drill bit? Coming up against concrete? (it's a 1950s maisonette, brick and concrete)?
Have attached some pics, for what it's worth.
And help would be greatly appreciated.
Cheers!
[img]http://img837.imageshack.us/i/36236781.jpg/[/img]
[img]http://img830.imageshack.us/i/60326663.jpg/[/img]
[img]http://img808.imageshack.us/i/53559020.jpg/[/img][/url]
by stoneyboy » Sun Jul 25, 2010 10:14 pm
tonyade,
You're hitting a concrete lintol which will have reinforcing bar(s) in it. Use a better drill and bit or make the hole further away from the lintol.
tonyade
by tonyade » Mon Aug 02, 2010 5:04 pm
Thanks, Stoneyboy!
by stoneyboy » Tue Aug 03, 2010 10:44 pm
tonyade,
Just possible if you have a modern house that you are hitting a steel lintol.
It is currently Mon Nov 25, 2024 10:33 pm
