Cavity Tray
Oznarda
Cavity Tray
by Oznarda » Tue Mar 06, 2007 11:35 am
I have just had an inspection by the council and have been advised that I need to install a cavity tray. However having spoken to a builder he suggested that if the planning application was approved prior to this being a requirement then I could avoid installing the tray, planning was approved about 4 years ago. Does anyone know when cavity trays became a requirement or where I could find out.
John
sparrow
by sparrow » Wed Mar 07, 2007 2:51 pm
Dodgy builder really John. The building regs are there to protect you and your property. If you have added a building to an outside wall that wall has now become an inside wall. If any water gets into the cavity, as it regularly does, there is a danger (because it can no longer soak through the wall and evapourate) of it making damp or cold spots on your new "inside" wall. This is why a cavity tray is inserted and to omit it is asking for trouble. People do not think twice about changing a car tyre when its a bit worn but are continually taking chances with a huge investment like a house because some builders give advice which is at best appalling.
Oznarda
by Oznarda » Fri Mar 09, 2007 9:42 am
Thanks Sparrow, builder booked to come and sort at the weekend!
thedoctor
by thedoctor » Fri Mar 16, 2007 12:53 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Wed Feb 05, 2025 12:47 pm
